[GRASS-dev] Re: [GRASS GIS] #617: r.sim.water crashes on WinGrass
GRASS GIS trac at osgeo.org
Thu May 28 09:22:04 EDT 2009
  Reporter:  hamish        |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect        |      Status:  new
  Priority:  normal        |   Milestone:  6.4.0
 Component:  Raster        |     Version:  6.4.0 RCs
Resolution:                |    Keywords:  wingrass, r.sim.water
  Platform:  MSWindows XP  |         Cpu:  x86-32
Comment (by hamish):
 ==17249== ERROR SUMMARY: 100051 errors from 16 contexts (suppressed: 129
 from 1)
 ==17249== malloc/free: in use at exit: 20,153,050 bytes in 5,227 blocks.
 ==17249== malloc/free: 23,104 allocs, 17,877 frees, 421,163,496 bytes
 allocated.
 G65> CMD="r.sim.water --o elevin=${dem} dxin=${dem}_dx dyin=${dem}_dy \
           rain=${dem}_rain manin=${dem}_manin infil=${dem}_infil \
           depth=${dem}_depth disch=${dem}_disch err=${dem}_err"
 G65> g.gisenv set=DEBUG=3
 G65> valgrind --tool=memcheck --leak-check=yes --show-reachable=yes  $CMD
 ==17249== Memcheck, a memory error detector.
 ==17249== Copyright (C) 2002-2006, and GNU GPL'd, by Julian Seward et al.
 ==17249== Using LibVEX rev 1658, a library for dynamic binary translation.
 ==17249== Copyright (C) 2004-2006, and GNU GPL'd, by OpenWorks LLP.
 ==17249== Using valgrind-3.2.1-Debian, a dynamic binary instrumentation
 framework.
 ==17249== Copyright (C) 2000-2006, and GNU GPL'd, by Julian Seward et al.
 ==17249== For more details, rerun with: -v
 ==17249==
 ==17249== Warning: set address range perms: large range 308011008
 (defined)
 ==17249== Warning: set address range perms: large range 308051968
 (defined)
 ==17249== Warning: set address range perms: large range 308002816
 (defined)
 D2/3: G__read_Cell_head
 D2/3: G__read_Cell_head_array
 D3/3: region item: proj:       1
 D3/3: region item: zone:       13
 D3/3: region item: north:      4928000
 D3/3: region item: south:      4914020
 D3/3: region item: east:       609000
 D3/3: region item: west:       590010
 D3/3: region item: cols:       633
 D3/3: region item: rows:       466
 D3/3: region item: e-w resol:  30
 D3/3: region item: n-s resol:  30
 D3/3: region item: top:        1
 D3/3: region item: bottom:     0
 D3/3: region item: cols3:      633
 D3/3: region item: rows3:      466
 D3/3: region item: depths:     1
 D3/3: region item: e-w resol3: 30
 D3/3: region item: n-s resol3: 30
 D3/3: region item: t-b resol:  1
 D3/3: rain_val is set to: -999.990000
 D3/3: manin_val is set to: -999.990000
 D3/3: infil_val is set to: -999.990000
 default nwalk=589956, rwalk=589956.000000
 D3/3: Running MAY 10 version, started modifications on 20080211
 D3/3: region item: format:     1
 D3/3: region item: compressed: 1
 D3/3: create window mapping (633 columns)
 D3/3: region item: format:     -1
 D3/3: region item: format:     0
 D0/3: beginning memory allocation for output grids
 D0/3: after gama
 D0/3: after gammaS
 D0/3: seeding randoms
 Min elevation = 1066.00 m
 Max elevation = 1840.00 m
 Mean Source Rate (rainf. excess or sediment) = 0.000001 m/s or kg/m2s
 Mean flow velocity = 8.428620 m/s
 Mean Mannings = 0.050837
 Number of iterations = 168 cells
 Time step = 0.89 s
 D2/3:  maxwa, nblock 589956 1
 D2/3:  barea,sarea,rwalk,sisum: 900.000000 0.000000 589956.000000 0.290123
 D2/3:  number of written walkers: 0
 D2/3:  nwalk, maxw 870369 7000000
 D2/3:  walkwe (walk weight),frac 589956.000000 0.800000
 D2/3:  deldif,factor 0.754644 4.375899e-07
 D2/3: main loop over the projection time...
 D2/3: iblock=1 i=33 miter=168 nwalk=870369 nwalka=856968
 D2/3: iblock=1 i=66 miter=168 nwalk=870369 nwalka=849676
 D2/3: iblock=1 i=99 miter=168 nwalk=870369 nwalka=844371
 D2/3: iblock=1 i=132 miter=168 nwalk=870369 nwalka=839828
 D2/3: iblock=1 i=165 miter=168 nwalk=870369 nwalka=836022
  100%
 ==17249== Conditional jump or move depends on uninitialised value(s)
 ==17249==    at 0x40A0B34: (within /usr/lib/libz.so.1.2.3)
 ==17249==    by 0x40A17C7: (within /usr/lib/libz.so.1.2.3)
 ==17249==    by 0x40A1F3F: deflate (in /usr/lib/libz.so.1.2.3)
 ==17249==    by 0x403F615: G_zlib_compress (flate.c:339)
 ==17249==    by 0x403F2E1: G_zlib_write (flate.c:213)
 ==17249==    by 0x405AA3F: G__write_data_compressed (put_row.c:337)
 ==17249==    by 0x405AED4: put_fp_data (put_row.c:468)
 ==17249==    by 0x405B67B: put_raster_data (put_row.c:695)
 ==17249==    by 0x405BE69: put_raster_row (put_row.c:909)
 ==17249==    by 0x405A6C3: G_put_raster_row (put_row.c:225)
 ==17249==    by 0x405A723: G_put_f_raster_row (put_row.c:235)
 ==17249==    by 0x1AE12469: output_data (output.c:197)
 ==17249==
 ==17249==    at 0x40A0B4C: (within /usr/lib/libz.so.1.2.3)
 ==17249==
 ==17249==    at 0x40A0B64: (within /usr/lib/libz.so.1.2.3)
 ==17249==
 ==17249==    at 0x40A0AB0: (within /usr/lib/libz.so.1.2.3)
 ==17249==
 ==17249==    at 0x40A0ACC: (within /usr/lib/libz.so.1.2.3)
 ==17249==
 ==17249==    at 0x40A0AE8: (within /usr/lib/libz.so.1.2.3)
 ==17249==
 ==17249==    at 0x40A0B04: (within /usr/lib/libz.so.1.2.3)
 ==17249==
 ==17249==    at 0x40A0B1C: (within /usr/lib/libz.so.1.2.3)
 ==17249==
 ==17249==    at 0x40A0A67: (within /usr/lib/libz.so.1.2.3)
 ==17249==
 ==17249==    at 0x40A0A71: (within /usr/lib/libz.so.1.2.3)
 ==17249==
 ==17249==    at 0x40A0A87: (within /usr/lib/libz.so.1.2.3)
 D1/3: close elevation.dem_depth compressed
 ==17249==
 ==17249== Invalid read of size 4
 ==17249==    at 0x4010DE9: (within /lib/ld-2.3.6.so)
 ==17249==    by 0x4004B78: (within /lib/ld-2.3.6.so)
 ==17249==    by 0x4006792: (within /lib/ld-2.3.6.so)
 ==17249==    by 0x47F946F: (within /lib/tls/i686/cmov/libc-2.3.6.so)
 ==17249==    by 0x400B44E: (within /lib/ld-2.3.6.so)
 ==17249==    by 0x47F8EDE: _dl_open (in /lib/tls/i686/cmov/libc-2.3.6.so)
 ==17249==    by 0x47FB6FC: (within /lib/tls/i686/cmov/libc-2.3.6.so)
 ==17249==    by 0x47FB75D: __libc_dlopen_mode (in
 ==17249==    by 0x47D57CF: __nss_lookup_function (in
 ==17249==    by 0x47D58BF: (within /lib/tls/i686/cmov/libc-2.3.6.so)
 ==17249==    by 0x47D74E5: __nss_passwd_lookup (in
 ==17249==  Address 0x6F6C624 is 36 bytes inside a block of size 38 alloc'd
 ==17249==    at 0x401D38B: malloc (vg_replace_malloc.c:149)
 ==17249==    by 0x4006B83: (within /lib/ld-2.3.6.so)
 ==17249==    by 0x4785B6E: getpwuid_r (in
 ==17249==
 ==17249==    at 0x4008ED5: (within /lib/ld-2.3.6.so)
 ==17249==    by 0x47F98C4: (within /lib/tls/i686/cmov/libc-2.3.6.so)
 ==17249==    by 0x4785499: getpwuid (in /lib/tls/i686/cmov/libc-2.3.6.so)
 ==17249==
 ==17249==    at 0x4008B2E: (within /lib/ld-2.3.6.so)
 ==17249==
 ==17249==    at 0x4010DD3: (within /lib/ld-2.3.6.so)
 ==17249==    by 0x7EE0169: (within
 /lib/tls/i686/cmov/libnss_compat-2.3.6.so)
 ==17249==    by 0x7EE128C: _nss_compat_getpwuid_r (in
 ==17249==  Address 0x72497D8 is 32 bytes inside a block of size 35 alloc'd
 ==17249==    by 0x4785A94: getpwuid_r (in
 ==17249==
 ==17249==    by 0x400A1F6: (within /lib/ld-2.3.6.so)
 ==17249==    by 0x400A3CA: (within /lib/ld-2.3.6.so)
 ==17249==    by 0x47F94D4: (within /lib/tls/i686/cmov/libc-2.3.6.so)
 ==17249==  Address 0x7338C84 is 36 bytes inside a block of size 37 alloc'd
 D1/3: close elevation.dem_disch compressed
 D1/3: close elevation.dem_err compressed
 D3/3: G_recreate_command()
 ==17249==
 from 1)
 allocated.
 ==17249== For counts of detected errors, rerun with: -v
 ==17249== searching for pointers to 5,227 not-freed blocks.
 ==17249== checked 638,301,564 bytes.
 ==17249==
 ==17249==
 ==17249== 1 bytes in 1 blocks are still reachable in loss record 1 of 22
 ==17249==    at 0x401DB31: operator new(unsigned)
 (vg_replace_malloc.c:163)
 ==17249==    by 0x579926F: (within /usr/lib/libgeos.so.2.2.3)
 ==17249==    by 0x57E8F04: (within /usr/lib/libgeos.so.2.2.3)
 ==17249==    by 0x575E938: (within /usr/lib/libgeos.so.2.2.3)
 ==17249==    by 0x400B7F4: (within /lib/ld-2.3.6.so)
 ==17249==    by 0x400B920: (within /lib/ld-2.3.6.so)
 ==17249==    by 0x40007EE: (within /lib/ld-2.3.6.so)
 ==17249==
 ==17249==
 ==17249== 1 bytes in 1 blocks are still reachable in loss record 2 of 22
 ==17249==    by 0x57B91DF: (within /usr/lib/libgeos.so.2.2.3)
 ==17249==
 ==17249==
 ==17249== 8 bytes in 1 blocks are still reachable in loss record 3 of 22
 ==17249==    by 0x47D55CD: __nss_lookup_function (in
 ==17249==    by 0x7EE01E1: ???
 ==17249==    by 0x7EE128C: ???
 ==17249==    by 0x4069C40: G_whoami (whoami.c:70)
 ==17249==    by 0x4047B78: G_short_history (history.c:207)
 ==17249==    by 0x403448C: close_new (closecell.c:311)
 ==17249==    by 0x4033BD7: G_close_cell (closecell.c:81)
 ==17249==    by 0x1AE12B12: output_data (output.c:271)
 ==17249==    by 0x804A959: main (main.c:525)
 ==17249==
 ==17249==
 ==17249== 8 bytes in 1 blocks are still reachable in loss record 4 of 22
 ==17249==    by 0x57CDC5D: (within /usr/lib/libgeos.so.2.2.3)
 ==17249==
 ==17249==
 ==17249== 16 bytes in 1 blocks are possibly lost in loss record 5 of 22
 ==17249==    by 0x47C284B: tsearch (in /lib/tls/i686/cmov/libc-2.3.6.so)
 ==17249==    by 0x47D558E: __nss_lookup_function (in
 ==17249==
 ==17249==
 ==17249== 16 bytes in 1 blocks are still reachable in loss record 6 of 22
 ==17249==    by 0x5770523: geos::GeometryFactory::GeometryFactory() (in
 ==17249==    by 0x576B25A: (within /usr/lib/libgeos.so.2.2.3)
 ==17249==
 ==17249==
 ==17249== 16 bytes in 1 blocks are still reachable in loss record 7 of 22
 ==17249==    by 0x576B250: (within /usr/lib/libgeos.so.2.2.3)
 ==17249==
 ==17249==
 ==17249== 24 bytes in 1 blocks are still reachable in loss record 8 of 22
 ==17249==    by 0x57E7DEF: (within /usr/lib/libgeos.so.2.2.3)
 ==17249==
 ==17249==
 ==17249== 28 bytes in 1 blocks are still reachable in loss record 9 of 22
 ==17249==    by 0x57A701F: (within /usr/lib/libgeos.so.2.2.3)
 ==17249==
 ==17249==
 ==17249== 32 bytes in 4 blocks are indirectly lost in loss record 10 of 22
 ==17249==    by 0x7EE0187: ???
 ==17249==
 ==17249==
 ==17249== 64 bytes in 4 blocks are indirectly lost in loss record 11 of 22
 ==17249==    by 0x7EE01C3: ???
 ==17249==
 ==17249==
 ==17249== 132 (36 direct, 96 indirect) bytes in 1 blocks are definitely
 lost in loss record 12 of 22
 ==17249==    by 0x47D5A09: (within /lib/tls/i686/cmov/libc-2.3.6.so)
 ==17249==    by 0x47D60F6: __nss_database_lookup (in
 ==17249==    by 0x7EE0149: ???
 ==17249==
 ==17249==
 ==17249== 256 bytes in 1 blocks are still reachable in loss record 13 of
 22
 ==17249==    by 0x57B91F3: (within /usr/lib/libgeos.so.2.2.3)
 ==17249==
 ==17249==
 ==17249== 256 bytes in 1 blocks are still reachable in loss record 14 of
 22
 ==17249==    by 0x57CDC3F: (within /usr/lib/libgeos.so.2.2.3)
 ==17249==
 ==17249==
 ==17249== 1,200 bytes in 1 blocks are possibly lost in loss record 15 of
 22
 ==17249==    by 0x402EB8D: G__malloc (alloc.c:41)
 ==17249==    by 0x405CC4B: quant_table_increase (quant.c:582)
 ==17249==    by 0x405CE52: G_quant_add_rule (quant.c:661)
 ==17249==    by 0x405E313: G_quantize_fp_map_range (quant_rw.c:166)
 ==17249==    by 0x1AE12EFF: output_data (output.c:320)
 ==17249==
 ==17249==
 ==17249== 3,925 bytes in 409 blocks are definitely lost in loss record 16
 of 22
 ==17249==    by 0x40650B8: G_store (store.c:36)
 ==17249==    by 0x403EEAB: find_file (find_file.c:101)
 ==17249==    by 0x403EF4B: find_file1 (find_file.c:126)
 ==17249==    by 0x403EFD9: G_find_file_misc (find_file.c:167)
 ==17249==    by 0x40454E3: open_null_read (get_row.c:995)
 ==17249==    by 0x4045711: get_null_value_row_nomask (get_row.c:1063)
 ==17249==    by 0x4045C21: get_null_value_row (get_row.c:1186)
 ==17249==    by 0x4045CC7: embed_nulls (get_row.c:1204)
 ==17249==    by 0x4045086: get_map_row_no_reclass (get_row.c:650)
 ==17249==    by 0x4045140: get_map_row (get_row.c:678)
 ==17249==
 ==17249==
 ==17249== 6,628 bytes in 4 blocks are still reachable in loss record 17 of
 22
 ==17249==    at 0x401C6CA: calloc (vg_replace_malloc.c:279)
 ==17249==    by 0x402EC00: G__calloc (alloc.c:74)
 ==17249==    by 0x4057090: G_recreate_command (parser.c:2805)
 ==17249==    by 0x4047C20: G_command_history (history.c:259)
 ==17249==    by 0x1AE14021: output_data (output.c:552)
 ==17249==
 ==17249==
 ==17249== 8,338 bytes in 4 blocks are still reachable in loss record 18 of
 22
 ==17249==    at 0x401D487: realloc (vg_replace_malloc.c:306)
 ==17249==    by 0x402EC83: G__realloc (alloc.c:111)
 ==17249==    by 0x403D108: set_env (env.c:156)
 ==17249==    by 0x403CEA9: read_env (env.c:104)
 ==17249==    by 0x403D6F0: G__getenv (env.c:317)
 ==17249==    by 0x403D627: G_getenv (env.c:271)
 ==17249==    by 0x404B0E4: G_location (location.c:63)
 ==17249==    by 0x404B109: G__location_path (location.c:78)
 ==17249==    by 0x404B07E: G_location_path (location.c:41)
 ==17249==    by 0x40467C4: G__gisinit (gisinit.c:58)
 ==17249==    by 0x8049A6C: main (main.c:115)
 ==17249==
 ==17249==
 ==17249== 11,776 bytes in 1 blocks are still reachable in loss record 19
 of 22
 ==17249==    by 0x402EC6C: G__realloc (alloc.c:109)
 ==17249==    by 0x404E644: new_fileinfo (opencell.c:42)
 ==17249==    by 0x404EAEE: G__open_cell_old (opencell.c:274)
 ==17249==    by 0x404E704: G_open_cell_old (opencell.c:104)
 ==17249==    by 0x1AE0F794: input_data (input.c:180)
 ==17249==    by 0x804A66D: main (main.c:478)
 ==17249==
 ==17249==
 ==17249== 13,704 bytes in 5 blocks are definitely lost in loss record 20
 of 22
 ==17249==    by 0x402EE30: G_allocate_f_raster_buf (alloc_cell.c:113)
 ==17249==    by 0x1AE0F0CB: input_data (input.c:89)
 ==17249==
 ==17249==
 ==17249== 20,288 bytes in 5 blocks are possibly lost in loss record 21 of
 22
 ==17249==    by 0x402EE72: G_allocate_d_raster_buf (alloc_cell.c:128)
 ==17249==    by 0x1AE0F0D3: input_data (input.c:90)
 ==17249==
 ==17249==
 ==17249== 20,086,429 bytes in 4,778 blocks are still reachable in loss
 record 22 of 22
 ==17249==    by 0x4059CD0: G_set_program_name (progrm_nme.c:52)
 ==17249==    by 0x404677C: G__gisinit (gisinit.c:51)
 ==17249==
 ==17249== LEAK SUMMARY:
 ==17249==    definitely lost: 17,665 bytes in 415 blocks.
 ==17249==    indirectly lost: 96 bytes in 8 blocks.
 ==17249==      possibly lost: 21,504 bytes in 7 blocks.
 ==17249==    still reachable: 20,113,785 bytes in 4,797 blocks.
 ==17249==         suppressed: 0 bytes in 0 blocks.
Ticket URL: <https://trac.osgeo.org/grass/ticket/617#comment:1>
