[GRASS-dev] [GRASS GIS] #621: v.in.mapgen: add cats to lines
GRASS GIS trac at osgeo.org
Fri May 29 13:35:10 EDT 2009
 Reporter:  hamish              |       Owner:  grass-dev at lists.osgeo.org
     Type:  enhancement         |      Status:  new
 Priority:  normal              |   Milestone:  6.5.0
Component:  Vector              |     Version:  svn-trunk
 Keywords:  v.in.mapgen, ascii  |    Platform:  All
      Cpu:  All                 |
 it would be nice if v.in.mapgen would add sequentially increasing cat
 numbers to the lines it imports. currently all lines are without cat.
 either by simply running `v.category opt=add` after the import or
 by modifying the awk script to create cat numbers directly in the
 v.in.ascii file.
 thanks,
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/621>
