[GRASS-dev] Re: [GRASS GIS] #622: grass64 startup error with wxpython
GRASS GIS trac at osgeo.org
Fri May 29 19:10:27 EDT 2009
  Reporter:  neuba        |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect       |      Status:  new
  Priority:  normal       |   Milestone:  6.4.0
 Component:  default      |     Version:  unspecified
Resolution:               |    Keywords:
  Platform:  Unspecified  |         Cpu:  Unspecified
Comment (by hamish):
 > >>>>>>> .merge-right.r37559
 you had a conflict after 'svn up'. You need to edit, remove, or move away
 the wxgui.py file then 'svn resolved wxgui.py' and 'svn up' to restore it,
 and try try again.
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/622#comment:1>
