[GRASS-dev] Re: [GRASS GIS] #799: Add -o option to muliple import of GDAL data
GRASS GIS trac at osgeo.org
Mon Nov 2 18:45:23 EST 2009
  Reporter:  trochtaj     |       Owner:  martinl
      Type:  enhancement  |      Status:  assigned
  Priority:  normal       |   Milestone:  6.4.0
 Component:  wxGUI        |     Version:  unspecified
Resolution:               |    Keywords:  import, multi
  Platform:  Unspecified  |         Cpu:  Unspecified
Comment (by hamish):
 (meta-comment)
 for new flags, please* avoid -o, -q, and -v as there will be namespace
 confusion with the expanded versions of --o, etc. In a similar vein, try
 to avoid -l and -1 if you can as with some fonts they look the same.
 [*] unless the fit is just so good that anything else would be silly...
 please, no changes in behaviour to 6.4.x at this point unless it is a
 critical bug fix or harmless documentation change.
 and please, only backport to 6.5svn new features that are just so cool
 that you can't bear to live without them.
 discipline in this regard is the only way we will be able to break the
 current release logjam.
 thanks much,
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/799#comment:3>
