[GRASS-dev] Re: [GRASS-user] Access mapsets out of grass (small problem when launching a grass session)
Tue Nov 3 00:13:29 EST 2009
[CC to grass-dev]
Νίκος  	Αλεξανδρής wrote:
> However, I have a small problem: sometimes I launch grass6_dev or
> grass_trunk (my default is grass64) and whenever I hit Ctrl+C to break a
> running process, it happens sometimes to hit it twice and this breaks
> also the grass(6_dev or _trunk) session to break.
This appears to have been introduced in:
	http://trac.osgeo.org/grass/changeset/39350#file3
It doesn't appear to be in 7.0, though; if you're seeing it there, I
don't know what's causing it.
The change is a mistake, and should be reverted or modified.
The motivation appears to have been to allow the GUI to kill the
shell; in which case, it should have used some other signal (e.g.
SIGTERM, SIGHUP, SIGQUIT).
