[GRASS-dev] Re: [GRASS GIS] #800: r.random - buffer overflow on long mapset/map names
GRASS GIS trac at osgeo.org
Wed Nov 4 11:59:28 EST 2009
  Reporter:  ferrouswheel  |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect        |      Status:  new
  Priority:  normal        |   Milestone:  6.4.0
 Component:  Raster        |     Version:  svn-develbranch6
Resolution:                |    Keywords:
  Platform:  All           |         Cpu:  All
Comment (by glynn):
 Replying to [ticket:800 ferrouswheel]:
 > In r.random/support.c there are sprintf calls which cause buffer
 overflow errors when the map names and mapsets are too long. I've attached
 a patch to replace with snprintf.
 snprintf() isn't in C89; if you want to use it, you need to add a
 configure check, and provide an alternate in case it isn't available.
Ticket URL: <http://trac.osgeo.org/grass/ticket/800#comment:2>
