[GRASS-dev] Re: [GRASS GIS] #795: v.out.ogr and centroids in GRASS 6.2.1 and PostGIS
GRASS GIS trac at osgeo.org
Thu Nov 5 02:49:03 EST 2009
  Reporter:  hancar   |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect   |      Status:  closed
  Priority:  normal   |   Milestone:
 Component:  default  |     Version:  unspecified
Resolution:  fixed    |    Keywords:  v.out.ogr centroid grass postgis gentoo
  Platform:  Linux    |         Cpu:  x86-32
Changes (by mmetz):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Also happened with current release branch and any OGR format. Fixed in
 relbr6 r39682 because I think it is a bug, centroids could not be
 exported. Was already fixed in devbr6 and trunk. The memory leaks in
 relbr6 persist, these are also only fixed in devbr6 and trunk. Just for
 the record, areas are best exported with v.out.ogr -c type=area. Closing
 ticket.
Ticket URL: <https://trac.osgeo.org/grass/ticket/795#comment:1>
