[GRASS-dev] Re: [GRASS GIS] #76: Calculation of bearing between 2 points, using d.measure
GRASS GIS trac at osgeo.org
Tue Nov 10 05:03:18 EST 2009
  Reporter:  dylan        |       Owner:  grass-dev at lists.osgeo.org
      Type:  enhancement  |      Status:  new
  Priority:  minor        |   Milestone:  6.5.0
 Component:  default      |     Version:  unspecified
Resolution:               |    Keywords:  d.measure
  Platform:  Unspecified  |         Cpu:  Unspecified
Comment (by glynn):
 Replying to [comment:1 dylan]:
 > Has anyone had a chance to review this patch for submission to trunk
 yet?
 The "trunk" is 7.0, which doesn't have d.measure or the functionality it
 requires (the ability to query the mouse pointer).
 The code is still there, but it doesn't compile due to the absence of
 R_get_location_with_pointer(). It was retained in case it was felt
 worthwhile to modify it to take x,y coordinates via command-line options
 or stdin, rather than via the mouse. As the functionality has been added
 directly to the GUI, it's likely that d.measure will be removed
 altogether.
Ticket URL: <https://trac.osgeo.org/grass/ticket/76#comment:5>
