[GRASS-dev] Re: [GRASS GIS] #76: Calculation of bearing between 2 points, using d.measure
GRASS GIS trac at osgeo.org
Tue Nov 10 20:47:21 EST 2009
  Reporter:  dylan        |       Owner:  grass-dev at lists.osgeo.org
      Type:  enhancement  |      Status:  new
  Priority:  minor        |   Milestone:  6.5.0
 Component:  default      |     Version:  unspecified
Resolution:               |    Keywords:  d.measure
  Platform:  Unspecified  |         Cpu:  Unspecified
Comment (by hamish):
 everything is already there for command line use from r.transect,
 r.profile, as Markus points out m.cogo (although that is primarily
 designed to mirror US survey definitions), and * swig/python/m.distance.py
 also there is code in d.geodesic and d.rhumbline to play with.
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/76#comment:10>
