[GRASS-dev] Re: [GRASS GIS] #775: r.terraflow: file=/home/mlennert/STREAM/STREAM_tQhXkQ:cannot read!: Bad address
GRASS GIS trac at osgeo.org
Wed Nov 11 08:58:13 EST 2009
address
  Reporter:  mlennert  |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect    |      Status:  closed
  Priority:  normal    |   Milestone:  6.4.0
 Component:  Raster    |     Version:  6.4.0 RCs
Resolution:  fixed     |    Keywords:  terraflow aborted
  Platform:  Linux     |         Cpu:  Unspecified
Changes (by neteler):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Replying to [comment:10 fram]:
 > I tried to apply the patch of r.terraflow (r.terraflow.diff).  I do not
 know if I did it fine, what I did was to change the original
 "include/iostream/ami_sort_impl.h" file with the modifications in the
 .diff file. If this was fine, below is the output of r.terraflow which to
 me seems to give a different error as before.
 For the record: the user didn't compile with LFS support. Done that, the
 patch works.
 Fixed in 6.4 (r39700), 6.5 (r39701), 7 (r39702). Closing.
Ticket URL: <http://trac.osgeo.org/grass/ticket/775#comment:11>
