[GRASS-dev] wish problem
William Kyngesburye woklist at kyngchaos.com
Wed Nov 11 09:42:26 EST 2009
Since you mention frameworks, I assume you mean my package.
I bundled TclTk within the GRASS 6.3 application.  It's X11-based, unlike later versions where I use an external Aqua TclTk.  You shouldn't have to set any GRASS variables for it to work.
I haven't looked at GRASS 6.3 in a long time, so I don't know what might be wrong.  Do you have X11 installed?  It's an optional install on your OSX system disk (you'll need it for *any* kind of map display in GRASS, not just TclTk).
You could try GRASS 6.4.  It's quite solid.  I moved the Tiger builds to my download archives page, and won't be making any more packages for Tiger (and certainly not for GRASS 6.3), but it still works.
On Nov 11, 2009, at 5:03 AM, Martin Bratschi wrote:
> Dear All,
> I am very new to GRASS and also command based programs (only some experience with R) but very much interested in getting into GIS and using it for my studies.
> I have downloaded GRASS 6.3.0 onto my Mac (OS X 10.4.11) and also included all necessary (as far as I can tell) frameworks.
> However, when I start GRASS I get the following error:
> WARNING: The wish command does not work as expected!
> Please check your GRASS_Wish environment variable.
> I have been reading online trying to solve this problem and have done/found the following:
> $ which wish
> gives me:
> /usr/bin/wish
> $ wish
> Opens a small window named Wish Shell (About Tcl & TK: Tcl 8.4.7 & Tk 8.4.7).
> I did (in Darwin):
> GRASS_WISH=wish8.4
> export GRASS_WISH=usr/bin/wish8.4
> After all of this the error when starting GRASS is still there.
> Would you be able to help with this?
> Please let me know if you would require any further information about my system.
> Thank you very much for your help.
> Best regards,
> Martin
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"This is a question about the past, is it? ... How can I tell that the past isn't a fiction designed to account for the discrepancy between my immediate physical sensations and my state of mind?"
- The Ruler of the Universe
