[GRASS-dev] Re: [GRASS GIS] #809: v.db.addtable consistently fails in winGrass
GRASS GIS trac at osgeo.org
Fri Nov 13 12:21:21 EST 2009
  Reporter:  JonBall          |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect           |      Status:  new
  Priority:  critical         |   Milestone:  6.4.0
 Component:  Vector           |     Version:  svn-releasebranch64
Resolution:                   |    Keywords:  addtable
  Platform:  MSWindows Vista  |         Cpu:  x86-64
Comment (by hellik):
 tested in MSYS-shell:
 GRASS 6.4.0svn (nc_spm_08):c:/osgeo4w/apps/grass/bin > v.db.addtable
 map=mysoils layer=2 col="left integer, right int
 eger"
 Using vector map name extended by layer number as table name: mysoils_2
 Creating table with columns (cat integer, left integer, right integer)
 The table <mysoils_2> is now part of vector map <mysoils> and may be
 deleted or overwritten by GRASS modules
 Select privileges were granted on the table
 Reading features...
  100%
 Updating database...
  100%
 0 categories read from vector map (layer 2)
 0 records updated/inserted (layer 2)
 Current attribute table links:
 layer <1> table <mysoils> in database
 <C:\gisdata\grassdata/nc_spm_08/user1/dbf/> through driver <dbf> with key
 <cat>
 layer <2> table <mysoils_2> in database
 <cat>
 Vector map <mysoils at user1> is connected by:
Ticket URL: <http://trac.osgeo.org/grass/ticket/809#comment:2>
