[GRASS-dev] Re: Translations not activated for wx startup screen?
Mon Nov 16 10:14:15 EST 2009
Markus Neteler wrote:
> I wonder if all the GUI code needs to be cluttered with the
> import gettext stuff? A global switch might be nicer...
Can you elaborate?
Each module needs to call gettext.install() in order to add the _()
function to the module's namespace.
However, I have no idea why gis_set.py calls it three times.
