[GRASS-dev] Fwd: Using GRASS to calculate an index
Luis Lisboa luislisboa1975 at gmail.com
Thu Nov 19 07:07:11 EST 2009
Greetings All
I'm planning on developing an index to use over RASter images. Is quite an
easy expression with a few sums and square roots. All those operations are
included in r.mapcalc but instead of doing each operation using image
calculation in GUI I want to do an automatic procedure in which I select
image A, image B and Image C and he does the rest.
Question: Since those operations are included in r.mapcalc, do I need to do
a function or can I just do a Script that is called from the wxPython GUI?
Thanks
Cheerios
Luis Lisboa
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20091119/8656020e/attachment.html
