[GRASS-dev] Re: [GRASS-windows] Compile r.example for GRASS6.4 in Windows
Thu Nov 19 15:07:51 EST 2009
António Rocha wrote:
> cannot find -lgrass_datetime
> There is no file with that name neigter lxdr neither liberty. The this
> is at grass.make DATETIME_LIBNAME is defined:
> DATETIME_LIBNAME      = grass_datetime
> and then DATETIMELIB is defined as
> DATETIMELIB   = -l$(DATETIME_LIBNAME)
> so DATETIMELIB is equal to lgrass_datetime
No, it's equal to -lgrass_datetime (note the leading dash); -l is a
switch; the linker adds the "lib" prefix itself.
