[GRASS-dev] Make files for g.extension
John A Stevenson john.stevenson at manchester.ac.uk
Fri Nov 20 04:30:45 EST 2009
I wrote an addon (r.denoise) that I would like to be able to use with
g.extension.  I am running 6.5.svn from my home directory, so that I
have permissions to install extra modules without sudo.  The
installation fails, telling me that the module did not install correctly
(see below).  I have a few questions:
- is this a problem with 1) my 6.5.svn installation, 2) with
g.extension, or 3) with the r.denoise addon?
- if 1) or 3), how can I fix it?  Do I need to change the Make file for
r.denoise?
I have trouble installing other addons (r.surf.volcano,
r.colors.quantiles), so if the problem is with the addons, then it will
affect them, too.
Cheers
John
GRASS 6.5.svn (thingy):~/laptop/grassdata/thingy > g.extension r.denoise
Fetching <r.denoise> from GRASS-Addons SVN (be patient)...
A    r.denoise/description.html
A    r.denoise/r.denoise
A    r.denoise/Makefile
Checked out revision 39770.
Compiling r.denoise...
/home/mbessjs3/usr/local/grass-6.5.svn/include/Make/Script.make:47:
warning: overriding commands for target `install'
/home/mbessjs3/usr/local/grass-6.5.svn/include/Make/Rules.make:82:
warning: ignoring old commands for target `install'
if [ ! -d
/home/mbessjs3/usr/local/src/grass/develbranch_6/dist.i686-pc-linux-gnu/scripts
]; then mkdir -p
/home/mbessjs3/usr/local/src/grass/develbranch_6/dist.i686-pc-linux-gnu/scripts;
fi
/usr/bin/install -c  r.denoise
/home/mbessjs3/usr/local/src/grass/develbranch_6/dist.i686-pc-linux-gnu/scripts/r.denoise
make htmlscript scriptstrings
make[1]: Entering directory
`/media/OS/Users/mbessjs3/Documents/grassdata/thingy/PERMANENT/.tmp/mbessjs3-pc/16278.0/r.denoise'
make
/home/mbessjs3/usr/local/src/grass/develbranch_6/dist.i686-pc-linux-gnu/docs/html/r.denoise.html
HTMLSRC=/home/mbessjs3/usr/local/src/grass/develbranch_6/dist.i686-pc-linux-gnu/scripts/r.denoise
make[2]: Entering directory
if [
"/home/mbessjs3/usr/local/src/grass/develbranch_6/dist.i686-pc-linux-gnu/scripts/r.denoise"
!= "" ] ; then
GISRC=/home/mbessjs3/usr/local/src/grass/develbranch_6/dist.i686-pc-linux-gnu/demolocation/.grassrc65
GISBASE=/home/mbessjs3/usr/local/src/grass/develbranch_6/dist.i686-pc-linux-gnu
PATH="/home/mbessjs3/usr/local/src/grass/develbranch_6/dist.i686-pc-linux-gnu/bin:$PATH"
LD_LIBRARY_PATH="/home/mbessjs3/usr/local/src/grass/develbranch_6/dist.i686-pc-linux-gnu/bin:/home/mbessjs3/usr/local/src/grass/develbranch_6/dist.i686-pc-linux-gnu/lib:/home/mbessjs3/usr/local/grass-6.5.svn/lib"
LC_ALL=C
--html-description < /dev/null | grep -v '</body>\|</html>' >
r.denoise.tmp.html ; true ; fi
/home/mbessjs3/usr/local/grass-6.5.svn/tools/mkhtml.sh r.denoise ; mkdir
-p
; /usr/bin/install -c  -m 644 r.denoise.tmp.html
; for file in  *.png *.jpg ; do head -n 1 $file | grep '^#!' > /dev/null
; if [ $? -ne 0 ] ; then /usr/bin/install -c  -m 644 $file
; fi done 2> /dev/null ; true
make[2]: Leaving directory
PATH=/home/mbessjs3/usr/local/src/grass/develbranch_6/dist.i686-pc-linux-gnu/bin:$PATH
LD_LIBRARY_PATH="/home/mbessjs3/usr/local/src/grass/develbranch_6/dist.i686-pc-linux-gnu/lib:/home/mbessjs3/usr/local/grass-6.5.svn/lib"
g.parser -t r.denoise | sed s/\"/\\\\\"/g | sed 's/.*/_("&")/' >
/home/mbessjs3/usr/local/grass-6.5.svn/locale/scriptstrings/r.denoise_to_translate.c
; true
/bin/sh: cannot create
/home/mbessjs3/usr/local/grass-6.5.svn/locale/scriptstrings/r.denoise_to_translate.c:
Directory nonexistent
make[1]: Leaving directory
make mancmd
make
/home/mbessjs3/usr/local/src/grass/develbranch_6/dist.i686-pc-linux-gnu/man/man1/r.denoise.1
MANSRC=/home/mbessjs3/usr/local/src/grass/develbranch_6/dist.i686-pc-linux-gnu/docs/html/r.denoise.html
mkdir -p
GRASS_PERL=/usr/bin/perl VERSION_NUMBER=6.5.svn sh
/home/mbessjs3/usr/local/src/grass/develbranch_6/tools/g.html2man/g.html2man
1
Converting:
to
Installing r.denoise...
ERROR: Module did not install properly
Dr John Stevenson
Postdoctoral Research Associate
School of Earth, Atmospheric and Environmental Sciences
Williamson Building (Room 2.42)
University of Manchester
Manchester M13 9PL, UK
tel. +44(0)161 306 6585; fax. +44(0)161 306 9361;
