[GRASS-dev] Re: [GRASS GIS] #820: r.in.wms doesn't work in WinGRASS installer distribution
GRASS GIS trac at osgeo.org
Fri Nov 20 17:50:40 EST 2009
  Reporter:  ddalimonte    |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect        |      Status:  new
  Priority:  normal        |   Milestone:  6.4.0
 Component:  Packaging     |     Version:  svn-releasebranch64
Resolution:                |    Keywords:  r.in.wms
  Platform:  MSWindows XP  |         Cpu:  Unspecified
Comment (by hellik):
 Replying to [comment:7 hellik]:
 with debug
 r.in.wms layers=global_mosaic mapserver=http://wms.jpl.nasa.gov/wms.cgi
 output=wms_global_mosaic
 which: wget: unknown command
 c:/OSGeo4W/apps/grass/grass-6.4.0svn/scripts/r.in.wms: eval:
 line 1: unexpected EOF while looking for matching `''
 line 2: syntax error: unexpected end of file
 Calculating tiles
 c:/osgeo4w/apps/grass/grass-6.4.0svn/scripts/r.tileset:
 [0]=SOURCE_PROJ: command not found
 [1]=1: command not found
 [2]=DEST_PROJ: command not found
 [3]=SOURCE_TO_DEST: command not found
 [0]=DEST_PROJ: command not found
 [1]=SOURCE_PROJ: command not found
 [2]=1: command not found
 [3]=DEST_TO_SOURCE: command not found
 (standard_in) 2: parse error
 Rel. 4.7.1, 23 September 2009
 <cs2cs.exe>:
 projection initialization failure
 cause: Unknown error
 program abnormally terminated
 ERROR: Problem running cs2cs. <Using from definition: >
 ERROR: r.tileset failure
 ERROR: wms.request failure
Ticket URL: <https://trac.osgeo.org/grass/ticket/820#comment:9>
