[GRASS-dev] Re: [GRASS GIS] #815: ps.map geogrid label overlap at the region corner
GRASS GIS trac at osgeo.org
Fri Nov 20 18:08:09 EST 2009
  Reporter:  maning  |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect  |      Status:  new
  Priority:  minor   |   Milestone:  7.0.0
 Component:  ps.map  |     Version:  unspecified
Resolution:          |    Keywords:  geogrid
  Platform:  All     |         Cpu:  All
Changes (by hamish):
  * keywords:  => geogrid
  * platform:  Unspecified => All
  * cpu:  OSX/Intel => All
  * milestone:  6.4.0 => 7.0.0
Comment:
 [apparently trac doesn't like showing tiffs, so I uploaded a png version
 of the screenshot]
 this is not at all easy to fix as the code is not aware of what was
 previously written to the image.
 suggestions for work-arounds:
  - change your region settings slightly
  - edit the PostScript file in an industrial strength text editor like vi,
 search for the D:M:S text, and replace it with a blank space ( ).
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/815#comment:1>
