[GRASS-dev] [GRASS GIS] #823: r.param.scale will not accept fully qualified map names for output
GRASS GIS trac at osgeo.org
Sat Nov 21 11:09:03 EST 2009
 Reporter:  cmbarton  |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect    |      Status:  new
 Priority:  normal    |   Milestone:  6.4.0
Component:  default   |     Version:  6.4.0 RCs
 Keywords:            |    Platform:  All
      Cpu:  All       |
 r.param.scale raises an error if you enter a fully qualified map name
 (i.e., with the @mapset designation). While new maps can only be created
 in the current mapset, this should not cause an error.
 Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/823>
