[GRASS-dev] [GRASS GIS] #826: i.topo.corr fail to build
GRASS GIS trac at osgeo.org
Tue Nov 24 09:57:10 EST 2009
 Reporter:  yarma      |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect     |      Status:  new
 Priority:  normal     |   Milestone:  6.5.0
Component:  Compiling  |     Version:  svn-develbranch6
 Keywords:             |    Platform:  Linux
      Cpu:  x86-64     |
 I tried to build the addon i.topo.corr and get an error (other addons like
 i.landsat.toar worked fine).
 I did a fresh svn update on grass-addons, grass64_release, grass6_devel
 and grass_trunk, recompile the 3 grass version and there is always this
 compilation error ...
 # make MODULE_TOPDIR=/opt/grass65/grass-6.5.svn
 [[BR]]/opt/grass65/grass-6.5.svn/include/Make/Module.make:25: attention :
 écrasement des commandes pour la cible « install »
 [[BR]]/opt/grass65/grass-6.5.svn/include/Make/Rules.make:82: attention :
 anciennes commandes ignorées pour la cible « install »
 [[BR]]test -d OBJ.x86_64-unknown-linux-gnu || mkdir -p OBJ.x86_64-unknown-
 linux-gnu
 [[BR]]gcc -I/home/yarma/src_grass/grass6_devel/dist.x86_64-unknown-linux-
 gnu/include -I/usr/include/ -O0 -ggdb -Wall -Werror-implicit-function-
 declaration  -I/usr/include/     -DPACKAGE=\""grassmods"\"
 -I/home/yarma/src_grass/grass6_devel/dist.x86_64-unknown-linux-gnu/include
 -o OBJ.x86_64-unknown-linux-gnu/correction.o -c correction.c
 [[BR]]correction.c: In function ‘eval_tcor’:
 [[BR]]correction.c:12: attention : unused variable ‘i’
 -o OBJ.x86_64-unknown-linux-gnu/illumination.o -c illumination.c
 [[BR]]illumination.c: In function ‘eval_c_cosi’:
 [[BR]]illumination.c:14: attention : unused variable ‘i’
 [[BR]]illumination.c: In function ‘eval_f_cosi’:
 [[BR]]illumination.c:101: attention : unused variable ‘i’
 [[BR]]illumination.c: In function ‘eval_d_cosi’:
 [[BR]]illumination.c:188: attention : unused variable ‘i’
 -o OBJ.x86_64-unknown-linux-gnu/main.o -c main.c
 [[BR]]main.c: In function ‘main’:
 [[BR]]main.c:167: erreur: implicit declaration of function ‘eval_c_cosi’
 [[BR]]main.c:172: erreur: implicit declaration of function ‘eval_f_cosi’
 [[BR]]main.c:177: erreur: implicit declaration of function ‘eval_d_cosi’
 [[BR]]main.c:181: attention : le format n'est pas une chaîne littérale et
 pas d'argument de format
 [[BR]]main.c:210: attention : le format n'est pas une chaîne littérale et
 [[BR]]main.c:67: attention : unused variable ‘col’
 [[BR]]main.c:67: attention : unused variable ‘row’
 [[BR]]main.c:67: attention : unused variable ‘ncols’
 [[BR]]main.c:67: attention : unused variable ‘nrows’
 [[BR]]make: *** [OBJ.x86_64-unknown-linux-gnu/main.o] Erreur 1
Ticket URL: <http://trac.osgeo.org/grass/ticket/826>
