[GRASS-dev] Re: r.prominence fails to compile under grass 7
Michael Barton Michael.Barton at asu.edu
Fri Nov 27 12:08:38 EST 2009
I tried out the new code in GRASS 6.5 and 6.4. It does work much
better with the GUI and has no trouble with integer maps. It seems to
run faster, though maybe that's my imagination.
I tried it with a very small radius (3m) to see what happens and
posted the result.
http://www.public.asu.edu/~cmbarton/files/temp/pks_rprominence3.jpg
http://www.public.asu.edu/~cmbarton/files/temp/pks_rprominence3_nviz.jpg
One thing I forgot to mention is that at small sizes, r.prominence
creates an interesting red -> black -> white color table. But with
larger maps (e.g., the Spearfish DEM), it does not produce a viable
color table and the map appears blank. Running r.colors and picking a
color table fixes this, but it is probably something simple to fix in
the code too.
Best regards
Michael
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Arizona State University
Phone: 480-965-6262
Fax: 480-965-7671
www: www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On Nov 27, 2009, at 4:37 AM, Benjamin Ducke wrote:
> Try attached version. It should behave nicely with the GUI
> and also work with integer type input maps.
> Btw. the module is missing a man page. Wouldn't you like to
> write a small one, maybe including one of the beautiful images
> you created for illustration? We could then put r.prominence
> on the GRASS Add-ons page.
> Re. the GRASS 7 version, there seem to have been some major
> changes (finally) in the raster API. I would need to understand
> these first before I can update the source code for r.prominence,
> but there is no time for me to do that right now.
> Best,
> Ben
> ----- Original Message -----
> From: "Michael Barton" <michael.barton at asu.edu>
> To: "Benjamin Ducke" <benjamin.ducke at oxfordarch.co.uk>
> Cc: "list GRASS developers" <grass-dev at lists.osgeo.org>
> Sent: Thursday, November 26, 2009 1:25:20 AM GMT +01:00 Amsterdam /
> Berlin / Bern / Rome / Stockholm / Vienna
> Subject: r.prominence fails to compile under grass 7
> Benjamin,
> I've been testing r.prominence and it is pretty nice. I forgot to copy
> you on a recent post to the user list with screenshots, but I assume
> that you received it via the list.
> I've had no trouble compiling it on grass 6.4 and 6.5, but it failed
> with grass 7. The error is below.
> cmb-MBP-2:r.prominence cmbarton$ make
> test -d OBJ.i386-apple-darwin9.8.0 || mkdir -p OBJ.i386-apple-
> darwin9.8.0
> gcc -I/Users/cmbarton/grass_dev/grass7_src/dist.i386-apple-
> darwin9.8.0/
> include -I/Users/cmbarton/grass_dev/grass7_src/dist.i386-apple-
> darwin9.8.0/include  -g -O2     -I../dst/include  -DPACKAGE=
> \""grassmods"\"   -I/Users/cmbarton/grass_dev/grass7_src/dist.i386-
> apple-darwin9.8.0/include -I/Users/cmbarton/grass_dev/grass7_src/
> dist.i386-apple-darwin9.8.0/include -o OBJ.i386-apple-darwin9.8.0/
> main.o -c main.c
> main.c: In function ‘main’:
> main.c:72: error: storage size of ‘colors’ isn’t known
> main.c:74: error: ‘DCELL’ undeclared (first use in this function)
> main.c:74: error: (Each undeclared identifier is reported only once
> main.c:74: error: for each function it appears in.)
> main.c:74: error: ‘diskrow’ undeclared (first use in this function)
> main.c:76: error: ‘outrow’ undeclared (first use in this function)
> main.c:146: warning: assignment makes pointer from integer without a
> cast
> main.c:162: error: ‘DCELL_TYPE’ undeclared (first use in this
> function)
> make: *** [OBJ.i386-apple-darwin9.8.0/main.o] Error 1
> Also, the GUI doesn't work because it tries to reference something
> called fpmap, instead of something like old,cell,raster, and I don't
> think that is a valid item.
> BTW, I'll be at UCL and the IOA to give a talk on March 1. Maybe you
> can come down and say hi.
> Best
> Michael
> C. Michael Barton
> Phone: 480-965-6262
> Fax: 480-965-7671
> Files attached to this email may be in ISO 26300 format (OASIS Open
> Document Format). If you have difficulty opening them, please visit http://iso26300.info
>  for more information.
> <r.prominence.tar.gz>
