[GRASS-dev] [GRASS GIS] #829: v.in.ogr: when pointing to a folder import of vectors can produce wrong results
GRASS GIS trac at osgeo.org
Mon Nov 30 14:56:09 EST 2009
results
 Reporter:  lutra     |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect    |      Status:  new
 Priority:  major     |   Milestone:  6.4.0
Component:  Vector    |     Version:  6.4.0 RCs
 Keywords:  v.in.ogr  |    Platform:  All
      Cpu:  x86-32    |
 I was giving a try to v.in.ogr pointing to a folder containing a few
 shapfiles and the results didn't convinced me. So I made a simple test.
 *) Created two simple shapefiles each containing one polygon, each polygon
 partially overlapping the one in the other shape
 *) Placed the shapes in one folder and run "v.in.ogr -o
 dsn=/home/gio/test_shapes output=test_import"
 The expected result was to obtain two layers each with one feature, as in
 the original shapes.
 Instead I get 3 layers:
 *) One with one feature, representing the overlap area
 *) Two representing the original polygons except for the fact they are
 made of two features: the "extra" feature is the overlap area
 Seems wrong to me, considering that if the poligons in the sample shapes
 do not overlap, then the results are the expected ones.
Ticket URL: <http://trac.osgeo.org/grass/ticket/829>
