[GRASS-dev] Re: [GRASS GIS] #595: WinGRASS g.version -c fails
GRASS GIS trac at osgeo.org
Thu Oct 1 22:30:37 EDT 2009
  Reporter:  hamish        |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect        |      Status:  new
  Priority:  blocker       |   Milestone:  6.4.0
 Component:  License       |     Version:  6.4.0 RCs
Resolution:                |    Keywords:  wingrass gpl
  Platform:  MSWindows XP  |         Cpu:  x86-32
Comment (by hamish):
 > When Makefile runs:
 cat ./../../COPYING | sed -f sed.script | tr -d '\012' > /src/dev_6/dist.
 i686-pc-mingw32/etc/VERSION
 sed: file sed.script line 1: Unknown option to 's'
 (sed.script contains {{{ s/.*$/&\\n/g }}})
 so what is this Makefile line doing exactly?
  - It's copying the COPYING file into the $GISBASE/etc/VERSION file
  - it's terminating each line with a literal '\n'
  - it's removing all actual newline chars from the file.
 So this is getting the file ready to be a string embedded in the C code.
 The g.version Makefile has it with comments:
 # cat the COPYING file, add a c line-break \n at each line end
 # and remove the unix newline.
 COPYING=`cat ./../../COPYING | sed -f sed.script | tr -d '\012'`
 EXTRA_CFLAGS=-DVERSION_NUMBER=\"'$(VERSION_NUMBER)'\"
   -DVERSION_DATE=\"'$(VERSION_DATE)'\"
   -DVERSION_UPDATE_PKG=\"'$(VERSION_UPDATE_PKG)'\"
   -DCOPYING="\"$(COPYING)\""
 COPYING:
 $(GRASS_VERSION_FILE)
 GRASS_CONFIGURE_PARAMS:
         head -n 7 ./../../config.status | tail -n 1 | sed 's+#++1' | tr -d
 '\012' > $(GRASS_BUILD_FILE)
 On linux 'strings' shows the COPYING text within the binary, from the
 native WinGrass Msys prompt it doesn't.
 strings `which g.version`
 so the COPYING: ... > VERSION make rule could be simplified into a
 straight cp?
 interestingly the build info string does make it into the WinGrass binary
 and the $GISBASE/etc/BUILD file also has the correct content in it.
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/595#comment:5>
