[GRASS-dev] Some wxGUI tests on Windows
Jarek Jasiewicz jarekj at amu.edu.pl
Fri Oct 2 04:34:33 EDT 2009
Hi
Markus Neteler pisze:
> - r.shaded.relief doesn't show any error but the result is completely NULL.
>   Perhaps due to the fact that it is a shell script? If so, I would suggest
>   to add a Windows test and to bail out rather than continue unless it
>    is substituted with the Python version (6.4.1?).
Is there some objectives to replace r.shaded.relief with C code?. It
looks like very easy task and I can do that when I have little more time.
Jarek
