[GRASS-dev] Re: [GRASS GIS] #689: wxgui - georectify: group does not exist
GRASS GIS trac at osgeo.org
Fri Oct 2 14:11:21 EDT 2009
  Reporter:  mlennert  |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect    |      Status:  new
  Priority:  major     |   Milestone:  6.5.0
 Component:  wxGUI     |     Version:  svn-develbranch6
Resolution:            |    Keywords:  wxgui georectify
  Platform:  All       |         Cpu:  All
Changes (by cmbarton):
  * priority:  normal => major
  * platform:  Unspecified => All
  * version:  6.4.0 RCs => svn-develbranch6
  * cpu:  Unspecified => All
Comment:
 It's not completely clear from the description, but I'm pretty sure that
 this is fixed. Basically, georectification was broken because it was not
 running i.rectify in the source (xy) location. Hence, it could not find
 the group in the source location. I've fixed this. But there is still a
 problem with creating a group from the georectifier because it is
 switching back out of the source location when i.group is run. If this is
 not reported elsewhere, I'll open a separate ticket on this.
 I'm also not sure whether this is reported for 6.4 or 6.5 (see
 properties). I've fixed this for 6.4. 6.5 is also broken but in a
 different way.
 I'm closing this for 6.4 but leaving it open for version 6.5 because I
 suspect that there are similar causes to 6.5 breaking.
 Michael
Ticket URL: <https://trac.osgeo.org/grass/ticket/689#comment:2>
