[GRASS-dev] Re: i.rgb.his/i.his.rgb and 16bit images
Georg Kaspar georg at muenster.de
Wed Oct 7 03:06:48 EDT 2009
Hamish wrote:
> Georg wrote:
>> Actually the purpose was pansharpening.
> i.fusion.brovey -q
yes, i know this module, but i wanted to compare different approaches ;)
>> This could also be done with principal components, but grass
>> lacks an inverse-pca module as far as i know...
> maybe Nikos could comment.
> Note that with the R-grass bridge you can use any of the many R
> statistical methods + functions.
R is great as long as your datasets are small. problems arise when you
try to process l a r g e image files in R...
> ps- patch added in the trac system to allow i.rbg2his to work
> with 11-bit data (I fixed the truncation to 255 you saw before),
> but d.his and i.his2rgb are still 8-bit only for now. Waiting
> on word that I'm on the right track before moving onto the other
> modules.
thanks for that. i'm shure this is a nice improvement and one reason
less to use erdas...;)
