[GRASS-dev] Re: [GRASS GIS] #111: r.los fails in WinGRASS with high values for max_dis parameter
GRASS GIS trac at osgeo.org
Thu Oct 8 10:07:13 EDT 2009
  Reporter:  gsancho       |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect        |      Status:  new
  Priority:  major         |   Milestone:  6.4.0
 Component:  Raster        |     Version:  svn-develbranch6
Resolution:                |    Keywords:  wingrass r.los
  Platform:  MSWindows XP  |         Cpu:  x86-32
Comment (by aborruso):
 Hi helli,
 for me yes. I have had this problem in the past, but it's all ok with
 WinGRASS-6.4.0SVN-r39271-1.
 I have made a test with this command:
 r.los --overwrite input=DEM at PERMANENT output=vis coordinate=304000,4211134
 max_dist=50000
 Thank you,
 a
Ticket URL: <http://trac.osgeo.org/grass/ticket/111#comment:23>
