[GRASS-dev] Re: [GRASS GIS] #773: r.in.gdal unclean import of
southern UTM zone
trac at osgeo.org
Fri Oct 9 07:19:55 EDT 2009
#773: r.in.gdal unclean import of southern UTM zone
Reporter: hamish | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: Projections/Datums | Version: svn-develbranch6
Resolution: | Keywords: r.in.gdal, utm
Platform: Unspecified | Cpu: Unspecified
Comment (by pkelly):
Hi Hamish,
How long ago was the location created? g.setproj had a bugfix on 7 October
2003 to create a negative zone number for southern hemisphere UTM
locations (<http://freegis.org/cgi-
bin/viewcvs.cgi/grass6/general/g.setproj/main.c.diff?r1=1.15&r2=1.16>).
Are you saying that that doesn't work (i.e. the negative zone doesn't go
into the WINDOW file) because libgis doesn't handle negative zone numbers?
If so that would make this an incredibly long-running bug...
Ticket URL: <https://trac.osgeo.org/grass/ticket/773#comment:1>
