[GRASS-dev] Re: [GRASS GIS] #775: r.terraflow: file=/home/mlennert/STREAM/STREAM_tQhXkQ:cannot read!: Bad address
GRASS GIS trac at osgeo.org
Fri Oct 9 11:16:53 EDT 2009
address
  Reporter:  mlennert  |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect    |      Status:  new
  Priority:  normal    |   Milestone:  6.4.0
 Component:  Raster    |     Version:  svn-develbranch6
Resolution:            |    Keywords:  terraflow bad address
  Platform:  Linux     |         Cpu:  Unspecified
Comment (by mlennert):
 Replying to [comment:4 glynn]:
 > Replying to [comment:3 mlennert]:
 > > Any ideas based on the backtrace ?
 > The backtrace doesn't entirely make sense, e.g. frame !#4 has:
 >         err = AMI_ERROR_NO_ERROR
 > so the assert() shouldn't be triggering. But that may just be an
 artifact of optimisation. Can you reproduce this if libiostream and
 r.terraflow are built without optimisation?
 Now I get err = AMI_ERROR_IO_ERROR.
Ticket URL: <http://trac.osgeo.org/grass/ticket/775#comment:5>
