[GRASS-dev] libgrass_iostream build problem...
cgnicholas at alamedanet.net cgnicholas at alamedanet.net
Fri Oct 9 19:30:46 EDT 2009
Hmmm - perhaps not so fast...my tmp area is an ext3 file system, and I
compiled everything with --largefiles, etc....hmmmm
Chris
		 FILL: 20.28G (21780347904) [388934784 elements, 56B each]
file=/home/cgn/tmp//STREAM_EoACCO:cannot read!: Bad address
r.terraflow:
/home/cgn/src/grass-6.4.0RC5/dist.i686-pc-linux-gnu/include/grass/iostream/ami_sort_impl.h:91:
size_t makeRun_Block(AMI_STREAM<T>*, T*, unsigned int, Compare*) [with T =
keyvalue<int>, Compare = keyCmpKeyvalueType<int>]: Assertion `err ==
AMI_ERROR_NO_ERROR || err == AMI_ERROR_END_OF_STREAM' failed.
cgn at maps:~$ cd tmp
cgn at maps:~/tmp$ df -k .
Filesystem           1K-blocks      Used Available Use% Mounted on
/dev/sda1            470148268  77855996 368410048  18% /
cgn at maps:~/tmp$
cgn at maps:~/tmp$ ls
STREAM_cYvU25  STREAM_J2CrzX  STREAM_TXsdtt  STREAM_Wgw7I0
STREAM_EoACCO  STREAM_tFmbMn  STREAM_UxXNFF  STREAM_WH31Yx
cgn at maps:~/tmp$ ls -la
total 6604764
drwxr-xr-x  2 cgn cgn        4096 2009-10-09 19:29 .
drwxr-xr-x 65 cgn root       4096 2009-10-09 19:11 ..
-rw-------  1 cgn cgn  3642522012 2009-10-09 19:29 STREAM_cYvU25
-rw-------  1 cgn cgn     2644176 2009-10-09 19:29 STREAM_EoACCO
-rw-------  1 cgn cgn  1555739136 2009-10-09 19:13 STREAM_J2CrzX
-rw-------  1 cgn cgn  1555739136 2009-10-09 19:29 STREAM_tFmbMn
-rw-------  1 cgn cgn           0 2009-10-09 19:29 STREAM_TXsdtt
-rw-------  1 cgn cgn           0 2009-10-09 19:13 STREAM_UxXNFF
-rw-------  1 cgn cgn           0 2009-10-09 19:29 STREAM_Wgw7I0
-rw-------  1 cgn cgn           0 2009-10-09 19:29 STREAM_WH31Yx
