[GRASS-dev] libgrass_iostream build problem...
Sat Oct 10 05:43:02 EDT 2009
cgnicholas at alamedanet.net wrote:
> file=/home/cgn/tmp//STREAM_5Xwb5K:cannot read!: Bad address
> r.terraflow:
> /home/cgn/src/grass-6.4.0RC5/dist.i686-pc-linux-gnu/include/grass/iostream/ami_sort_impl.h:91:
> size_t makeRun_Block(AMI_STREAM<T>*, T*, unsigned int, Compare*) [with T =
> keyvalue<int>, Compare = keyCmpKeyvalueType<int>]: Assertion `err ==
> AMI_ERROR_NO_ERROR || err == AMI_ERROR_END_OF_STREAM' failed.
> Aborted (core dumped)
Known bug (#775); see:
	http://trac.osgeo.org/grass/ticket/775
