[GRASS-dev] Re: [GRASS GIS] #783: r.watershed fails on wingrass
GRASS GIS trac at osgeo.org
Sat Oct 10 06:05:11 EDT 2009
  Reporter:  hamish        |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect        |      Status:  new
  Priority:  major         |   Milestone:  6.4.0
 Component:  Raster        |     Version:  6.4.0 RCs
Resolution:                |    Keywords:  r.watershed, wingrass
  Platform:  MSWindows XP  |         Cpu:  x86-32
Comment (by glynn):
 Replying to [comment:1 mmetz]:
 > > ps- will the .ram and .seg modules fail in GRASS 7 where uppercase
 option names are disallowed? (eg LS= and S=)
 No, because:
 > They still work in GRASS 7, probably because they don't call
 G_parser(argc, argv)?
 Right.
 > Not sure if this is a good idea not to call G_parser(argc, argv).
 I'm not sure if it really matters, given that these modules aren't
 supposed to be run directly by the user. In terms of style and structure,
 there are a couple of hundred more serious issues before worrying about
 G_parser().
 > > pps- should G_convert_dirseps_to_host() be done in the G_gisbase() and
 G_gisdbase() functions instead or making the modules do it?
 Eventually. But first you have to fix everything which expects pathnames
 to use "/".
 The existing "quick fix" approach is to use "/" internally and convert to
 "\" at the last moment.
Ticket URL: <https://trac.osgeo.org/grass/ticket/783#comment:2>
