[GRASS-dev] Re: [GRASS GIS] #785: wx location wizard: doesn't show all datum transform opts
GRASS GIS trac at osgeo.org
Sat Oct 10 18:22:30 EDT 2009
  Reporter:  hamish  |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect  |      Status:  new
  Priority:  major   |   Milestone:  6.4.0
 Component:  wxGUI   |     Version:  svn-develbranch6
Resolution:          |    Keywords:
  Platform:  Linux   |         Cpu:  x86-64
Comment (by hamish):
 Replying to [comment:2 cmbarton]:
 > Correction, the options are read from the datumtransform.table
 > file, datums and their defaults are read from the datum.table file.
 > There are only 2 transforms for nzgd49 and none for wgs84 in the
 > file.
 the 7-term and NTv2 transforms for nzgd49 are in the datumtransform.table
 file; the 3-term transform can be found in the datum.table file.
 The WGS84 3-term transform (+towgs84=0,0,0) is also in the datum.table
 file. The terms found in both those files must be combined for
 presentation to the user.
 Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/785#comment:3>
