[GRASS-dev] Re: [GRASS GIS] #785: wx location wizard: doesn't show all datum transform opts
GRASS GIS trac at osgeo.org
Sat Oct 10 21:08:15 EDT 2009
  Reporter:  hamish    |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect    |      Status:  new
  Priority:  critical  |   Milestone:  6.4.0
 Component:  wxGUI     |     Version:  svn-develbranch6
Resolution:            |    Keywords:  location wizard
  Platform:  Linux     |         Cpu:  x86-64
Changes (by hamish):
  * keywords:  => location wizard
  * priority:  major => critical
Comment:
 It is worse,
  * start wx loc wiz
  * some new name for the new loc'n
  * proj: nzmg
  * datum: nzgd49
  * transfrom parms: T53
  * Summary page: +dx,+dy,+dz are there (these are the "default" 3-param
 +towgs84 terms) *AND* the 7-term parms from T53. these are mutually
 exclusive.
 (no way to cut & paste out of the wizard summary beyond screenshots,
 sorry)
 also:
  * no way to clear/unselect transform params after clicking the [< Back]
 button, even if transform parms choice is removed.
  * if you cancel the wizard, then again start the loc wiz, enter a new
 name but on the Choose Method page don't click on anything but [Next >]
 (leaving default Select Coord Sys selected), you go straight to the
 (mostly empty) Summary page. Doesn't happen the first time.
 Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/785#comment:4>
