[GRASS-dev] Re: [GRASS GIS] #785: wx location wizard: doesn't show all datum transform opts
GRASS GIS trac at osgeo.org
Sun Oct 11 04:55:50 EDT 2009
  Reporter:  hamish    |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect    |      Status:  new
  Priority:  critical  |   Milestone:  6.4.0
 Component:  wxGUI     |     Version:  svn-develbranch6
Resolution:            |    Keywords:  location wizard
  Platform:  Linux     |         Cpu:  x86-64
Comment (by hamish):
 there is still some work to be done I'm afraid.. a g.setproj session
 should give some guidance.
 for other projections it is not asking all it needs to. e.g. LCC, TMerc
 never asks for lat_0, lon_0, etc.
 see general/g.setproj/proj-parms.table for a list of questions which need
 to be asked (or are hardwired) for a given projection.
 (see proj-desc.table to convert those to +proj4 terms)
 the wizard should also probably ask what units you want (see proj-
 units.table)
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/785#comment:11>
