[GRASS-dev] svn help
Martin Landa landa.martin at gmail.com
Tue Oct 13 06:41:45 EDT 2009
2009/10/13 Martin Landa <landa.martin at gmail.com>:
>> BTW...  I wrote r.stream.del module base on r.stream.basins code (i.e I
>> copied r.stream.basin to r.stram.del and modified the code. It is the only
>> relationship between that two modules.
> you probably copied also metadata dictionary (.svn). It could be the
> reason. The best way to fork a module is to use 'svn copy' otherwise
> logs are broken.
see
https://trac.osgeo.org/grass/wiki/HowToSVN#Forkingandcloningandmergingback
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
