[GRASS-dev] Re: [GRASS GIS] #783: r.watershed fails on wingrass
GRASS GIS trac at osgeo.org
Tue Oct 13 14:15:35 EDT 2009
  Reporter:  hamish        |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect        |      Status:  new
  Priority:  major         |   Milestone:  6.4.0
 Component:  Raster        |     Version:  6.4.0 RCs
Resolution:                |    Keywords:  r.watershed, wingrass
  Platform:  MSWindows XP  |         Cpu:  x86-32
Comment (by mmetz):
 I have successfully compiled grass-6.4.svn on XP, thanks to the detailed
 instructions!
 I tried double quotes, single quotes, space at the end, G_system() instead
 of system() and all combinations thereof. Nothing works. Only without any
 quotes around the $GISBASE/etc/r.watershed.[ram|seg] part does it run,
 otherwise I got the above described error. The new wxGUI, map display,
 r.info and v.info work, also r.watershed without the quotes.
 I used the latest OSGeo4W installer and
 grass-6.4.svn_src_snapshot_2009_10_10.tar.gz on XP 32 bit.
 Markus M
Ticket URL: <https://trac.osgeo.org/grass/ticket/783#comment:8>
