[GRASS-dev] Re: [GRASS GIS] #783: r.watershed fails on wingrass
GRASS GIS trac at osgeo.org
Wed Oct 14 10:05:02 EDT 2009
  Reporter:  hamish        |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect        |      Status:  new
  Priority:  major         |   Milestone:  6.4.0
 Component:  Raster        |     Version:  6.4.0 RCs
Resolution:                |    Keywords:  r.watershed, wingrass
  Platform:  MSWindows XP  |         Cpu:  x86-32
Changes (by glynn):
  * milestone:  6.4.1 => 6.4.0
Comment:
 Replying to [comment:8 mmetz]:
 > I tried double quotes, single quotes, space at the end, G_system()
 instead of system() and all combinations thereof. Nothing works. Only
 without any quotes around the $GISBASE/etc/r.watershed.[ram|seg] part does
 it run, otherwise I got the above described error. The new wxGUI, map
 display, r.info and v.info work, also r.watershed without the quotes.
 Does it work (with the quotes) if you add ".exe" to the end of the command
 name and/or use G_convert_dirseps_to_host()?
 I suspect that eliminating the quotes will mean that it fails if GRASS is
 installed in a directory which contains spaces, and without Administrator
 privileges you may be unable to install GRASS in a directory which doesn't
 contain spaces.
Ticket URL: <https://trac.osgeo.org/grass/ticket/783#comment:10>
