[GRASS-dev] Re: [GRASS GIS] #320: the ``default region'' term is somewhat misleading
GRASS GIS trac at osgeo.org
Wed Oct 14 22:56:36 EDT 2009
  Reporter:  1gray        |       Owner:  grass-dev at lists.osgeo.org
      Type:  enhancement  |      Status:  new
  Priority:  minor        |   Milestone:  7.0.0
 Component:  default      |     Version:  svn-trunk
Resolution:               |    Keywords:  region
  Platform:  All          |         Cpu:  All
Changes (by hamish):
  * keywords:  => region
  * platform:  Unspecified => All
  * version:  unspecified => svn-trunk
  * cpu:  Unspecified => All
Comment:
 it is the default region when creating new mapsets. thus it is the fall-
 back region setting. (if we really want to get into it, native French
 speakers can expand on the root of the word; but see closing comments
 below...)
 -> where in the code or docs do you find it to be confusing? The
 description for 'g.region -d' could certainly be improved to explain this
 better, tooltips added etc if you like.
 I don't think this is important enough to change the DEFAULT_WIND file
 name, or to break consistency when referencing that file. The WINDow half
 of the filename has already been abandoned as far as the user interface is
 concerned.
 as with #323, I think most semantic debates are best dealt with by honing
 the documentation and being consistent in the descriptions.
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/320#comment:2>
