[GRASS-dev] problems with datum parameters tables
Hamish hamish_b at yahoo.com
Thu Oct 15 02:10:15 EDT 2009
Michael wrote:
> After selecting the projection in the wizard, you go to a
> new page. Currently, if the projection is UTM, you get to
> select zone and hemisphere. If it is not UTM, you don't get
> to select any parameters. The UTM selection is hard wired
> into the GUI.
> I'm changing this so that the the parameters parsed from
> proj-parms.table appear for whatever projection is
> chosen--UTM or otherwise.
LL, UTM, and STP are not real projections so hardwiring them
as exceptions wouldn't be cause for alarm; but ok, if a single
method does the trick then no complaints from me...
cheers,
Hamish
