[GRASS-dev] OGR write access
Martin Landa landa.martin at gmail.com
Thu Oct 15 05:09:11 EDT 2009
I am thinking how to implement direct write access to OGR datasources
from the user point of view. One approach would be to implement global
flag '--u' for updating existing vector map (i.e. OGR datasource).
E.g.
v.out.ogr input=test dsn=. type=point -n
v.external dsn=. layer=test output=test
v.random out=test n=1000 --u
this could work also for native format
v.edit map=test tool=create
Or to add new parameters 'dns/format' which would be used only for OGR
format, not for the native one.
v.random out=test n=1000 format=ESRI_Shapefile dns=.
Any ideas?
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
