[GRASS-dev] Re: [GRASS GIS] #596: provide a grass-config script
GRASS GIS trac at osgeo.org
Fri Oct 16 02:31:52 EDT 2009
  Reporter:  hamish        |       Owner:  grass-dev at lists.osgeo.org
      Type:  enhancement   |      Status:  new
  Priority:  normal        |   Milestone:  7.0.0
 Component:  Installation  |     Version:  svn-trunk
Resolution:                |    Keywords:  gdal-plugin
  Platform:  All           |         Cpu:  All
Changes (by hamish):
  * keywords:  => gdal-plugin
Comment:
 idea for how this could be done:
 write a GRASS_BATCH_FILE which would start grass in a dummy location and
 run a single `g.version -b` command, then exit.
 (add new flags to g.version as needed for the info you want)
 or probably much simpler to just write a script which parses
 $GISBASE/include/Make/* as needed.
 gdal-config has:
 Usage: gdal-config [OPTIONS]
 Options:
         [--prefix[=DIR]]
         [--libs]
         [--dep-libs]
         [--cflags]
         [--datadir]
         [--version]
         [--ogr-enabled]
         [--formats]
 which of those would be useful in a grass-config? (obviously not the last
 two)
 any additional requests for options?
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/596#comment:2>
