[GRASS-dev] Re: [GRASS GIS] #775: r.terraflow: file=/home/mlennert/STREAM/STREAM_tQhXkQ:cannot read!: Bad address
GRASS GIS trac at osgeo.org
Fri Oct 16 13:30:51 EDT 2009
address
  Reporter:  mlennert  |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect    |      Status:  new
  Priority:  normal    |   Milestone:  6.4.0
 Component:  Raster    |     Version:  svn-develbranch6
Resolution:            |    Keywords:  terraflow bad address
  Platform:  Linux     |         Cpu:  Unspecified
Comment (by glynn):
 Replying to [comment:7 mlennert]:
 > Is this what you meant ?:
 You also need to uncomment at least one of the makeRun/makeRun_Block
 calls, otherwise it isn't actually reading anything. Or just leave the
 existing makeRun_Block call uncommented.
Ticket URL: <http://trac.osgeo.org/grass/ticket/775#comment:8>
