[GRASS-dev] Re: [GRASS GIS] #783: r.watershed fails on wingrass
GRASS GIS trac at osgeo.org
Sat Oct 17 07:18:13 EDT 2009
  Reporter:  hamish        |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect        |      Status:  closed
  Priority:  major         |   Milestone:  6.4.0
 Component:  Raster        |     Version:  6.4.0 RCs
Resolution:  fixed         |    Keywords:  r.watershed, wingrass
  Platform:  MSWindows XP  |         Cpu:  x86-32
Changes (by mmetz):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Replying to [comment:13 glynn]:
 > One of the first Google hits for "windows command syntax" suggests that
 two "levels" of quotes are required:
 > CMD /k ""c:\batch files\test.cmd" "Parameter 1 with space" "Parameter2
 with space""
 > Brief testing from the command line confirms this. I suggest trying this
 with both system() and G_system(); if the two don't match, then G_system()
 needs to add the outermost quotes itself.
 Adding outermost quotes works with both system() and G_system(), but only
 on Windows. Linux does not like the outermost quotes, but then there were
 no problems reported under Linux, therefore I have
 #ifdef __MINGW32__
 #endif
 the new quotes in r39541-3.
 Worksforme, closing ticket.
Ticket URL: <https://trac.osgeo.org/grass/ticket/783#comment:14>
