[GRASS-dev] OGR write access
Martin Landa landa.martin at gmail.com
Sat Oct 17 11:31:00 EDT 2009
2009/10/17 Markus Metz <markus.metz.giswork at googlemail.com>:
>> But probably GV_FORMAT_OGR_DIRECT would be better solution.
> Also to avoid rewriting existing code that uses GV_FORMAT_OGR for v.external
> linked vectors, see  e.g. [1,2].
> [1]
> https://trac.osgeo.org/grass/browser/grass/trunk/lib/vector/Vlib/open.c?rev=39545#L327
> [2]
> https://trac.osgeo.org/grass/browser/grass/trunk/lib/vector/Vlib/open.c?rev=39545#L437
right -  done in r39546.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
