[GRASS-dev] Re: [GRASS GIS] #785: wx location wizard: doesn't show all datum transform opts
GRASS GIS trac at osgeo.org
Sun Oct 18 06:13:24 EDT 2009
  Reporter:  hamish    |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect    |      Status:  new
  Priority:  critical  |   Milestone:  6.4.0
 Component:  wxGUI     |     Version:  svn-develbranch6
Resolution:            |    Keywords:  location wizard
  Platform:  Linux     |         Cpu:  x86-64
Comment (by hamish):
 just trying it out.. almost there.
  * for hardcoded "noask" values could the text boxes be greyed out? (e.g.
 NZMG, Lat/Lon's +lat_0,+lon_0 [could that 0,0 for LL just be removed from
 proj-parms.table?])
  * "datum :" does not get set in resulting PROJ_INFO file (#784) if
 selecting terms manually. This was fixed for a short time last week & then
 broke again a few days ago. (try running `g.region -p`) Creation using
 EPSG code works.
  * Expand boolean from N/Y to No/Yes. e.g. UTM Southern Hemisphere
 question the default is "N" which can also be "North". Better yet: figure
 out how to have it be 'Hemisphere: North|South'
  * For UTM, could 1-60 pulldown list be a constrained value spinbox
 instead?
  * Could datum transform list selection popup be integrated into the
 wizard [<Back] [Fwd>] pages, or at least be given the same window height x
 width? It seems a bit out of place. Better yet: could it have a radio
 button list like the Tcl/Tk version (try EPSG:27200). Also same as the Tcl
 version it should have a "continue without" option as well.
  * on the "Specify geodetic datum" page, could the Description column be
 made a bit wider by default? it's the long string and ellipsoid is the
 short one.
  * "Choose EPSG code" search is still a bit weird (need to reload to start
 a new search)
 thanks,
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/785#comment:26>
