[GRASS-dev] [GRASS GIS] #792: dbf driver: wrong column data type
GRASS GIS trac at osgeo.org
Sun Oct 18 08:35:47 EDT 2009
 Reporter:  martinl      |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect       |      Status:  new
 Priority:  normal       |   Milestone:  7.0.0
Component:  Database     |     Version:  svn-trunk
 Keywords:  data type    |    Platform:  Unspecified
      Cpu:  Unspecified  |
 DBF driver in GRASS 7 reports 'double' even if decimals is zero, e.g.
  D2/5:   DBFFieldType 2
 D3/5: add_column(): tab = 2, type = 3, name = cat, width = 11, decimals =
 0
 DOUBLE PRECISION|cat
 Attached patch forces 'integer' if 'double' with decimal = 0 is detected.
 I am not sure if it's right approach.
Ticket URL: <http://trac.osgeo.org/grass/ticket/792>
