[GRASS-dev] Re: [GRASS GIS] #792: dbf driver: wrong column data type
GRASS GIS trac at osgeo.org
Sun Oct 18 08:53:52 EDT 2009
  Reporter:  martinl      |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect       |      Status:  new
  Priority:  normal       |   Milestone:  7.0.0
 Component:  Database     |     Version:  svn-trunk
Resolution:               |    Keywords:  data type
  Platform:  Unspecified  |         Cpu:  Unspecified
Comment (by martinl):
 Replying to [comment:1 mmetz]:
 > I would first like to know why in grass7 integer fields with width > 10
 are considered double, contrary to grass6.x.
 > See also gdal ticket 809.
 Right, same problem with 'OGR' driver. There is no info about decimals
 [1].The attached patch is ugly workaround which cannot be applied in OGR
 driver.
 Martin
 [1] http://www.gdal.org/ogr/classOGRFieldDefn.html
Ticket URL: <http://trac.osgeo.org/grass/ticket/792#comment:2>
