[GRASS-dev] Re: [GRASS GIS] #792: dbf driver: wrong column data type
GRASS GIS trac at osgeo.org
Sun Oct 18 08:58:58 EDT 2009
  Reporter:  martinl      |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect       |      Status:  new
  Priority:  normal       |   Milestone:  7.0.0
 Component:  Database     |     Version:  svn-trunk
Resolution:               |    Keywords:  data type
  Platform:  Unspecified  |         Cpu:  Unspecified
Comment (by martinl):
 Replying to [comment:1 mmetz]:
 > In particular, why does the Makefile for the dbf driver now include
 $(GDALLIBS) but not in grass6.x?
 In the result dbf driver uses GDAL not ShapeLib. Removing $(GDALLIBS) from
 Makefile would be a quick solution. Anyway there is still problem with OGR
 driver. For every OGR layers is key column (if defined) reported as
 'double' which breaks most of GRASS modules.
Ticket URL: <http://trac.osgeo.org/grass/ticket/792#comment:3>
