[GRASS-dev] Re: [GRASS GIS] #792: dbf driver: wrong column data type
GRASS GIS trac at osgeo.org
Mon Oct 19 02:30:53 EDT 2009
  Reporter:  martinl      |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect       |      Status:  new
  Priority:  normal       |   Milestone:  7.0.0
 Component:  Database     |     Version:  svn-trunk
Resolution:               |    Keywords:  data type
  Platform:  Unspecified  |         Cpu:  Unspecified
Comment (by martinl):
 Replying to [comment:5 hamish]:
 > could you post here which DBF from the nc_ dataset you are using for
 tests?
 Sorry, I am not getting the point. AFAIU problem is a bug in GDAL/OGR when
 as a result 'integer' is detected as 'double precision', the very same for
 OGR driver in GRASS of course.
 Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/792#comment:7>
